Which monitor config would you choose, OC3D peeps?
Which monitor setup would you choose?
  • 1 x LG 34UM95-P
    Votes: 10 52.6%
  • 3 x Dell U2414H plus stand
    Votes: 9 47.4%
  • Total voters
    19
Davva2004
Active member
Hi all,
Quick poll to test the water here - I have a monitor config choice to make.
Option one: The rather lovely LG 34UM95-P 34" 21:9 ultra widescreen IPS 3840 x 1440 monitor at £659
OR:
Option two: THREE of the also rather lovely Dell U2414H 24" 16:9 IPS monitors with their 6mm wide bezels giving me 5760 x 1080, AND a triple monitor stand, which comes to a grand total of £588
GPU horsepower isn't an issue as there's two XFX 290X Double Dissipation cards pushing the pixels and there is literally only 1 megapixel difference between the two options.
And money really isn't an issue either considering how close the prices are.
So really, it comes down to visual appeal, usability, and wow factor.
So what would you guys choose and why?
Please choose an option in the poll, and feel free to leave a comment - especially if you have any alternatives for me to consider!
Never had a 3 monitor setup for gaming. But I have a 29'' 21:9 and I love it. Even though some games don't work very well in this aspect ratio. For those I play in 16:9 with black bars.
I reckon the three panels will be more stressful on the neck, cause you actually have to move your head to be able to look at all of them, although it will have better viewing angles cause you can set them up with a slight curve in them.
For some reason I wasn't able to vote...just shows the poll results (not sure why).
EDIT: Came back later, was able to....
You didn't mention usage, and most on boards like this are gamers, but I don't happen to be one. I'm a developer (game engines among the targets), and my usage pattern is all over the map outside of games. For that, the 3 monitor setup is highly preferred.
Regarding the valid point made above, 3 monitors do not present a single viewing field left to right, and you have to turn your head. You do get the sense of extra peripheral view, though with a band at each join perceived as a boundary of a glass window. More to the point, it's critical to get the angle correct for your viewing distance. Key is to ascertain what angle represents a perpendicular view as you face each monitor. It's all too easy to have them insufficiently angled, such that left and right monitors have a distorted relative position when compared to the central monitor. The angle depends on the distance between you and the monitors. The should be aligned as central tangents on a circle where you are at the center (such that you could complete a circle about you with all monitors at the same distance and relative angle once you face them).
I find it invaluable for research, coding, debugging and, as is my custom, running multiple virtual machines (in as many as 6 different operating systems at once).
Assuming Windows is the host, there are management features which make the 3 separate monitors work well as distinct regions. When you full screen an application, it occupies the one display it's on, not the others. Dividing research into multiple, distinct regions which permit references, sub-references and comparisons of complex research materials seems very natural in a multiple monitor setup.
That is quite counter to what you want in gaming. Of course, a game would easily expand to occupy 3 monitors (and it appears more games support that then the ultra wide format), but the result is quite different. A ultra wide view monitor teases at offering a workspace, for non gaming, which functions LIKE a multiple monitor setup, but I've yet to find a way to control Windows to provide similar organizational conveniences, other than those you'd use for any single monitor setup. You can tile, of course, but that works out beneficially only with 2 applications.
The other, contrary point is that, perceptively, it could be argued these are too wide. It's difficult to get a position whereby you don't witness a color shift, due to angle of view, from left to center or right to center. Further, your perception of font sizes and perpendicular intersections is slightly distorted, if you used the monitor for CAD, for example.
This isn't dramatic, so many might argue it's a non-issue. I point it out merely as a thought to examine as you choose. You may find the issue more pleasing than the multi-monitor arrangement, but I am the opposite.
Older eyes may tend to prefer the multiple monitor choice, in my view, because each represents a fairly conventional viewing experience for the size, and we tend to expect the setup to operate as 3 separate but related viewing surfaces, instead of one extended viewing surface.
I have used the 3 monitor arrangement in editing very wide graphics content. I was editing the backdrop to a kiosk display (some convention where booths for each company exhibiting wares is toured by crowds). The display was 24' by 8' at 300 DPI. The software was Adobe Illustrator, with associated 3DS Max and Photoshop contributions. It was effective to treat the combination as a single wide display, accounting for the separating band of each display, but work was naturally concentrated on the central monitor.
The issue I've always had with triple screen is that as a movie junkie you can only really watch movies single screen, which kind of ruins the experience... don't know if you're into movies but it's something to think about. Also the 21:9 will actually have more vertical pixels which can make web browsing a little more pleasant... I would get the 21:9
I would go with the triple monitor setup, but place them properly so you dont have to move your neck a lot. I think that 21:9 is a really nice screen but i dont like superwide resolutions on a screen like that.
I'd say go the LG the higher res single screen is easier than high res across 3, having used both myself Iam now enjoying the single high res screen
I'm with Excalabur on this one, I recently purchased the U3415W (a 34" curved) and was on a triple monitor setup before, and I'm really happy to have changed!
Consider the fact too that you will have more vertical estate with the LG than on the three monitors. It can be a real advantage considering the use you plan to make of the monitor.
I should add that it is way easier to focus on a wide large monitor than a three monitor setup. Unless you do productivity work, the "wow" effect of the large estate of the three monitors setupe might disappear after some time, and you might, like me, finish to not really use it.
as I don't like 21:9 screens (unless they are curved) I vote tripple screens.
Also I spotted a slight issue in the build you want to use for it but thats for another thread ;)
I think one large monitor looks nice etc and can be a pleasure for gaming. I can't do with the bezel with 3 monitors I am on two now at work and the bezel stresses me out. If I needed more productivity though I would go with 3 monitors and live with the bezel.
I want the LG now, it's going to be my next monitor. I have seen some reports of backlight bleed being very common and bad though
It is a lottery, some people have bleed issues, other not. But you can always RMA it until you have one who fits your tolerance. :p
I was lucky with my curved Dell, no bleeding issues and minimal IPS glow, but some people reports same problems as with the LG ones (same panels for both companies).
How much are you pricing a single Dell at?
Ah, now then I was pricing them up at £155 from Aria PC but now looking at their site they are discontinued and they don't have any. Next best price is £184 from CCL, they have loads of stock, and that pushes the combo price up to £672. So pretty much a match to the 34" LG.
Really pleased with the replies so far guys, it's virtually neck and neck and I appreciate the points made on both sides!
for productivity I cant live without tripple screens
This, this... this is a winning factor for tripple screens. But yet, it's nice with a huge curved monitor.
Most likely a dumb question, but how would one of those LG 27" or 34" (can't remember what size) be for gaming, such as like Battlefield 3/4?... and would it require a s**t ton more graphic horse power than what tripple monitors would be?. Or even a sinlge 27" 1440p?...
I'm just asking here as this I completely utterly suck at!... Hope you guys don't mind though!
I have quite a nice experience with the 34" curved on BF4. It's not as responsive as a 144hz panel, but the input lag is barely noticeable (well, for me) and the colors are incredible compared to my previous TN panels.
I spend the most of my time gaming on FF14 where, except on very crowded areas, my framerate is locked @ 60fps.
I run it on a single GTX 980 and don't have any framerate issues @ maximum settings.
And with new GPUs coming, I think it will be a very an even better option for people running on single card setup.
For reference, a triple 1080p monitor setup requires quite more power.
3440x1440 (resolution of the 34" 21: monitors) = 4953600 pixels
5760x1080 = 6220800 pixels
