T Tony9r New member Sep 29, 2007 #1 Hi all:wavey: , I've been using a Geforce FX5200 256MB AGP8X for a while now, and it's OK for the games I play, but I've just been given a Geforce 6200 256MB DDR AGP8X and was wondering if it's any better than the 5200? Tony.
T Toxcity New member Sep 29, 2007 #2 The 6200 is much better mate. But wouldn't you rather go for at least a 6800? they are cheap as chips these days!
T Tony9r New member Sep 29, 2007 #3 name='Toxcity' said: The 6200 is much better mate. But wouldn't you rather go for at least a 6800? they are cheap as chips these days! Click to expand... Hi Toxcity, I will eventually go for a better card, but as the 6200 was a freebie I'll stick that in for now Many thanks for your reply
T Tony9r New member Sep 29, 2007 #7 name='Toxcity' said: Ah, that makes sense! Hope you stick around mate! Click to expand... I'll stick around for sure mate... alway's got questions to ask on these technical pc things
K koganinja New member Sep 29, 2007 #8 has long has its a 6000 sieries you will be ok but you can get a 7000 for about 30 quide tops off ebay now
