wrenaudrey
I recently saw this video in youtube about this Acer monitor: Acer H236HL
And it looks amazing + its IPS!
So choices are:
Acer H236HL
LG IPS235v/LG IPS234v/LG IPS236v
Which one would you suggest?
Budget is max £150
I will be using for normal day to day and gaming, I would say im a midcore gamer.
Any others that you would recommend?
Thanks
PS. I cant seem to find anywhere in the UK that sells the LG IPS range.
PSS. Also what are your thought on input lag on other IPS monitors?
So choices are:
Acer H236HL
Budget is max £150
Thanks
