Which 8800gts
robump
Hi i am going to get and 8800 gts 640mb, but i wanted to know your views on which brand of card was best, here are the catogories.
Most overcloking head room.
Best core and memory clock speeds.
Cooling is not a problem becuase it will eventually get water coolled.
The spec of the build is hopefully gonna be:
E6600
Evga 680i T1 or Asus P5n-32-e SLI
Patriot 2G PC2 6400
Thanks
Rob :D
I have a palit 8800GTS. Yes I know there new to the buisness and are one of the cheapest around. But to be honest I am very impressed!
This thing overclocks a dream!
name='robump' said:
Is it worth getting higher clock speeds to begin with or should i overclock it myself?
Rob :D
I say overclock ya self! You will only end up paying more money for something you can DIY! :p
Get an XFX - if you can afford the "XXX" edition then get it cause they clocked the stream processors up which makes a big difference
i was thinking about evga 8800gts 640mb superclocked.
Memory 1700mhz
Core 576mhz
Also with evga you can overclock and not void warrenty.
Rob
