Nazzemannj
Hi, I'm about to upgrade my almost 1 year old gaming rig with a custom WC system.
My current specs:
Case: Caselabs STH10
MB: ASUS Rampage 4 Extreme
RAM: 4x4GB 1866MHz Corsair Dominator GT
CPU: Intel i7-3930K (Corsair H100 cooler)
GPU: Gainward Nvidia GeForce GTX 680 4GB Phantom
2x Kingston HyperX 3K 240GB SSD
2x Seagate Barracuda 1Tb HDD
I'll be watercooling the MB, CPU and the GPU, all on one loop. But what I'm here for, is to find out what GPU I should get.
Ever since I built my first PC, I've had a minor brand loyalty towards Gainward. This of course influenced my purchase of the 680 4GB Phantom. And I was originally going to get the Gainward 780 Phantom. But now I'm wondering if I should go for another brand for the 780. Which model would you guys propose. I have been sniffing at the ASUS 780 DirectCU II OC as I've heard a lot of good things about it. Then again, I've also heard lots of good stuff about EVGA in general, so I'm quite uncertain here.
Also, would the extra money put into a 780Ti be worth it? If so which model.
When it comes to budget, it doesn't really matter that much. But I'd like it to be cost efficient. Also, I wont go for a 780Ti unless it is really worth it. I'll be OC the card as well, so that has to come into the cost efficiency deal. Because if a cheaper card can be OC to somewhat equal a more expensive one that is also OCed, then I see no point going for the more expensive one.
I'd like to hear your opinions on this matter before I pop my WC virginity, as I wont go through the hassle of changing the GPU for a while.
-Nazz
My current specs:
-Nazz
