trawetSluaP
Member
I've looked everywhere and can't find it locally. Seems only deionised water is being sold an EK have said not to use it.
You can get it almost anywhere, Amazon, Ebay, Tescos.I've looked everywhere and can't find it locally. Seems only deionised water is being sold an EK have said not to use it.
Try the local pharmacy. I would be surprised if they couldn't get you distilled water since it's used for medical purposes.
https://www.amazon.co.uk/Bobbys-Healthy-Shop-BBS-35112-Distilled/dp/B0035FF28M
http://www.thedistilledwatercompany...dzz5wjbt3VeAvILRR4-KttbwZgJXwBWKzLxoCaBTw_wcB
Just get DeIonised stuff for car batteries from halfords, super cheap, just get a 5l tub. (it's also more pure than distilled)
You'll be fine if you use biocides and make sure your rad etc are all cleaned before filling the loop.
I assume that will be included in the EK coolant that comes with the Kit? It a brand new kit so I assume I won't need to clean it.
Yup always clean your stuff. It may have metal bits in, impurities etc.
I use distilled vinegar personally, then flush with distilled water.
How do you go about cleaning them?
