turbocrime
What's a good water pump to use i've got an einhem at the moment doesnt seem that great.
aXeR said:Depending on your personal preferences I'd get either:
Eheim 1250 (which is very powerful, had one for the past few months but due to its power, you need to dampen it to reduce vibration! Also, this pump needs to be plugged directly into the mains.
DangerDen D4 12v. I've just ordered this pump to replace my Eheim 1250, probably not quite as powerful (but still very powerful) the pump is a LOT smaller, vibrates a lot less, is quieter in general and due to the fact its powered by a 12v molex its possible to limit voltage via a rheobus.
name='Minstadave' said:I'm using a 1250, totally silent with a big bit of foam underneath it.
name='nick25' said:Yeah just wack a bit of foam underneath the 1250 and voila - silence. Could try the aquaextreme 12v pump - although it may be the same as the 12v DD one jujst different name.
name='nick25' said:Where can you get them? I ordered a lot from the US recently but no where had them in stock![]()
nick25 said:Cheers BAcon (is that bacon as in the food stuff or does BA stand for something and you're a con? British airways con? hmm, maybe not..) this was were I originally was going to buy it but they were out of stock - looks like they will be getting them in shortly though
EDIT: damn I love this new monitor - that whole sentance fitted on one line with room to spare.
