What to do ?
Dario_92
Hey there, I am currently debating on getting a GTX980 or do I get another GTX780 for sli ? Which would be the best option for me to go for ?
Thanks, Dario.
Well 2x780 will destroy a single 980, but if you are only gaming at 1080 2x780 is a bit overkill. A single 980 is perfect for 1080, saying that though, 2x780 will keep you going for at least a year or two before you needed to upgrade.
Yeah I'm only at 1080 forgot to mention that. I would like to get another 2 monitors and go triple screen setup but I dont have the room for it unfortunately lol. It works out cheaper for another 780 than buying a 980,but as you said it is overkill and the 980 would be good for 1080p.
