What is wrong with my mouse?
Tomi1337
As of late my Razer Naga (Molten Edition) has been a real pain in the ass.
When I boot up my computer or wake it from sleep mode it might not move at all. After molesting the mouse or waiting for a while it might move up and down. Then it maybe starts moving to the sides a bit. Then I unplug it, plug it back and wait.. And wait.. And it might start working! (A BIT :mellow:)
So here's another problem, the worst one propably.
It's very inaccurate at slow speeds. Take a look at these two professionally created images using advanced photoediting softwares and such.
Sometimes it works better, sometimes worse. It took me a couple of times to hit the "New Thread" button, so it's definitely bad right now.
I'm very seriously thinking of buying a new mouse and smashing this one with a sledgehammer, but first I'd like to know if this could be fixed by any means? Maybe smash it a bit more, open it up or something?
I'm a FPS gamer (CS:GO FTW atm) and nothing's more frustrating than trying to slightly move the crosshair at the enemy's head.. But the mouse decides not to move at all.
Sometimes it does these sweet 180 degree turns for no reason.
Oh and yeah, Razer Synapse's up to date.
Oh and yeah #2, I just updated something Naga related from Windows Update and it's even worse now. I move at 500 DPI doing these crazy sick circles while trying to move the mouse where I want to.
never use windows update for drivers, they usually make things worse or not even up to date. Instead of updating drivers, first uninstall all drivers related to your mouse, then run something like ccleaner to remove any traces of it left behind. Reboot your computer, then go to manufactures web site and find the appropriate drivers and install them again.
New drivers installed, now Razer Synapse says "Please connect a razer synapse 2.0 enabled device". meh.
Mouse still worked as bad, plugged the mouse off and on and now we've got only sideways movement.
How can this be a driver issue if it started slowly? First I thought it was the mousepad, I bought my friend's Goliathus Control. Now it again started doing these little sensor bugs and now it's going more worse day by day.
E: Allright, plugged it into the motherboard (Had in in the USB's in the front of the case for a while because of having to unplug it every few seconds) and Synapse found it.
Only problem being right now is that I can't move the mouse at all. Here I am pressing TAB trying to find the "Edit" buttons. Plugged it again and now it works as badly as it usually does.
Then I am going to go with Barnsley, it's broken. Always try the simple easy things first to trouble shoot, if that fails, pretty much pointing to hardware failure now.
Its Razer. It'll be broken.
/thread
This. Could also be mousepad, i had 2 Razer imperator's and neither of them liked textured mousepads. Had Razer Goliathus and the cursor jumped randomly on the green bits, but worked fine with black Steelseries QCK. Also both of them exploded within a year :ugly1:
