What does this meen
Oxo
basicially weneva i go to open up teamspeak this message appears (see attached) and it wont let me use my microphone. Any ideas....?
im not sure how, when i opend it on the site it came up with a lil zoom in pointer, i used that, if i dunt il re-upload
name='Toxcity' said:
Could you up the res of the piccar?
Can't read the error message.. :(
are you blind?
click the picture and then click it again when it opens and it will get big enough to read...
oxo:sure your mic is working properly?
and have you set it up correct?
try a re install of ts
i tried a re-install and that dint work, and i dont see y it would be a driver as it was workin a few days ago and i havnt changed anything to the headphones themselves or the setup etc.
i just did the normal install when i tried to re-install it, dint change anything, which is most proberly what i did first of all
i inserted my webcam into a usb port (which my ts auto used for my mic) and the error went away, but on settings my options are still set to use my headset :S
