name='Dave' said:xp-120 is overkill for ur amd, not needed...however i wanna change my vote to it cos then i can have it when u get ur prommy![]()
XMS said:Any UK peeps know where i can get a delta from? Or for that matter any fan with 190cfm or more?
Everywhere seems out of stock![]()
Austin said:Shame you don't live in Aussie, easy find
Except the Delta I see here is 220 CFM..
XMS said:GRR FFS i want one.
Whats the model no. of the 220cfm one?
Dave said:firstly get an idea of what you are in for.....
http://www.sidewindercomputers.com/del80ffb08123.html
then prepare yourself for 10db more.
http://www.sidewindercomputers.com/de12tfexhisp.html
you are not going to be able to put up with this jim
name='Dave' said:pfffft...good luck. i take it you havent listened to that..in fact i know you havent
name='Dave' said:yeah thats what i was thinking.....you wont be very popular at all.......
name='PV5150' said:I like your sound proofing idea Jim, go with the 220cfm screamer. It'd be easy to use some 10mm foam rubber to soundproof the case, peeps do it without even having a high dB fan in their cases.
Dave said:yeah but who sits and stares at thr comp all day??
cough* ionicle
cough* ionicle
