Hippie Tech
Hello OC3D !
I've seen my fair share of AM3/Deneb cpus, so I know what to expect when it comes to CPU and core temps. The cores are usually 3-7C cooler than what the CPU/socket sensor reports. As you can see, this is showing a huge gap.
My guess is that the core sensors are fine, even though they are lower that what I've seen online. From what I know, Thuban cores have about 50% more surface area than a Deneb. This means there is less empty space under the protective cap which normally traps heat. Also, the bigger surface area ensures that most/all of the cooler's heatpipes have some work to do. lol
What are your core/cpu temps and what cooling solution do you use ?
3DMark06 - core min 14C /max 23C, CPU min 28/ max37C - Zalman CNPS 9900NT w/ Qfan set to silent mode.
3DMark11 - core min 10.5C /max 19.5C, CPU min 26C /max 34C .. with a little -5C air blowing in the window.
3DMark11 x6 4 U
.. just because...
pEACe
3DMark11 x6 4 U
pEACe
