What 140mm fans to go on a H110?
corban
Unsure if this should be here or watercooling but as its fans ill out it here.
Got a H110 to go on my 3930k which will be clocked and in my cm storm stryker will have the front intake fans bring air in and the 140 in the back exhausting.
Which fans would be best for cooling with this setup ? I'm aware of 120 fans for cooling radiators but I've never used 140s to cool a radiator so interested in ideas would like them to be efficient but quiet.
Thanks
Edit have watched Toms H110 review and went with this as I can mount this in the top and because down the line I plan to watercool with a 280 in the roof and a 240 in the base at a later stage.
noctua has some quiet 140mm pressure fans
bit pricey and the usual noctua color though
nf a14 pwm i believe
These look pretty good too with High SP - http://www.prolimatech.com/en/products/detail.asp?id=1906
