well it aint gonna be a bulldozer!!!
badtaylorx
ok.....im jumping ship......can you guys help me ....i havent had an intel rig (not counting my atom/ion htpc) since p4...... ive got it down to 2 boards.....
1...ASUS P8P67 WS REVOLUTION the main draw i have to this is the pci16's are 4 slot spaced.....and i run 2 asus 6970dcii's
or
2...ASUS SABERTOOTH P67 ...
and would it be benificial to upgrade my mushkin radioactive 1600 cl7 ram to the 2000 blackline mushkin???
thanx for the help
bTx
Personally I'd go with the Sabertooth...but that's because i'm going with the sabertooth
You should be able to still fit two DirectCUii's in a sabertooth but I think they'd be right up against one another (bar a cm of space). I think the main problem would actually be from the PSU if it is mounted in the bottom of your case.
EDIT! Found a guy which put two Direct CUii 580's in a sabertooth and his case had a bottom mounted PSU...so yes, the sabertooth
Sabertooth. I have never been disappointed with the sabertooth boards. (I have the 990fx sabertooth in one right and the X58 Sabertooth in another.)
im running the 990 sabertooth right now actually......im just so p!$$ed off at amd's cpu division right now that im gonna overreact and buy an intel..
my case is a raven 02b-e so its a sudo top mount...on the side...
