Weird problem with Intel Edison and IMU MPU-9150
gigi
So I am trying to get measurements from the MPU-9150 sensor from Invensense using the Intel Edison. I am able to communicate with the sensor and the values seem sensible.
But after a specific number of cycles, I measure only a zero from all data registers. This error is repeatable: When I try to read the Accelerometer and Gyro data(6 data registers), the data stream stops exactly at 84 cycles. If I try to read jus the Accelerometer values, it stops at double the no. of cycles i.e. 168. I sense some data is overflowing, but couldn't figure out yet.
Looking for your reply and Thanks!
Cheers,
Frederic
Code:
Code:
MPU9150.h
#define GYRO_XOUT_L  0x44
#define GYRO_YOUT_H  0x45
#define GYRO_YOUT_L  0x46
#define GYRO_ZOUT_H  0x47
#define GYRO_ZOUT_L  0x48
//Power Management Registers
#define PWR_MGMT_1   0x6B
#define PWR_MGMT_2   0x6C
//Device i.d. Register
#define WHO_AM_I     0x75
R1 - 0x69
R2 - 0x68
#define MPU_ADDR     0x68
//Reset the Registers and Power
#define PWR_RESET    0x80
#define DEVICE_ON    0x00
//Accelerometer Scale
#define ACCEL_2G     0x00
#define ACCEL_4G     0x08
#define ACCEL_8G     0x10
#define ACCEL_16G    0x18
//Gyroscope Scale
#define GYRO_250     0x00
#define GYRO_500     0x08
#define GYRO_1000    0x10
#define GYRO_2000    0x18
#define SAMPLE_RATE  0x00
#define DLPF_CFG     0x01
MPU9150.c
Code:
    mraa_i2c_context mpu9150_i2c;
    mpu9150_i2c = mraa_i2c_init(1);
    //Set MPU Device Address
    mraa_i2c_address(mpu9150_i2c, MPU_ADDR);
    //Write Command and Data
    mraa_i2c_write_byte_data(mpu9150_i2c, value, address);
void MPU9150_I2C_Read(uint8_t address, uint8_t *value)
    //Set ALS Device Address
    //Write Command and Read Data
    *value = mraa_i2c_read_byte_data(mpu9150_i2c, address);
int16_t MPU9150_Get_Measurement(uint8_t addrL, uint8_t addrH)
    //Read & Store the Lower Byte
    MPU9150_I2C_Read(addrL, &Measurement_L);
    //Read & Store the Higher Byte
    MPU9150_I2C_Read(addrH, &Measurement_H);
  return (int16_t)((Measurement_H << 8) + Measurement_L);
//Signal Handler
void sig_handler(int signum)
    if(signum == SIGINT)
        isrunning = 0;
Console Screenshot:
