Webtemp
Epicurus
Does anyone here use webtemp???
I have reinstalled my PC and now webtemp does not seem to work.. BIOS temps are being read OK but when I go into windows and start webtemp it reads the CPU as 40deg and wont change.. Also it wont read the fan speed..
I have a shuttle AN50R
Use mbmlog mate, uses MBM5 to grab all the info and then puts it into an image file for you. See my sig for an example of what it does. Very customisable.
Cheers
Boardy
hmm odd, is it still red X? I can see it fine, it's not running atm tho, stopped it bout 10min ago. It may have been uploading the update when you looked, it does it every min.
Cheers
Boardy
