watercooling
Mullet
Lo all
what would you recommend for my rig? Would be able to spend around £250.
Has to cool dual 7800GTXs, FX55 and northbridge (is it worth w/c the northy/chipset?).
As you know I have an Akasa eclipse 62 case and would like all components installed internally....no swiftech radbox for me. :wavey:
Not worth to cool NB i dont think but..
2x Maze4gpu LP
Swiftech 6002 if you can find one (or apogee)
2x 50z's
BIX3 + sanyo denki's.
Specialtech Watercooling Section :D Thanks Kempz
Laing D5 link
We have the high flow hosing coming onto the site shortly.
Silenx Fans appear to be just as quiet
Radiators are here The black Ice Extreme II, which was reviewed in the Watercooling roundup by OC3D is recommended by this very forum :D
With the swiftech apogge, what fittings are you using to go from 1/2" tubing down to the blocks?
Full cover blocks have been proven not to do as good of cooling job as the GPU only blocks with some good BGA RAM sinks. With that said, I'm still a fan of the full cover blocks. The performance difference is VERY small between both types of setups but I think the full cover blocks give a more clean install and look to your loop.
I had a pair of NV78's from DD and they were VERY nice blocks. Highly suggested. Great for running SLI too.
Laing D5 link
Um dunno what connectors,...any suggestions guys...sorry about my noobishness with the w/c:yumyum:
Right final specs:
AquaXtreme MP05 LE SP CPU block (http://www.extremeprometeia.com/acatalog/aqz.html#a70)
Eddie EK 79 VGA blocks (SLI kit)
Eddie EK chipset block
Thermochill PA120.2
Alphacool DDC Ultra pump
Masterkleer - 7/16 tubing
Repak bay 5" bay res.
Thoughts??
Also, am considering going with red UV dye...or blue....does anyone have any pics to help me make my mind up?
Thanks again all for takign an interest.
:wavey:
Reco'd by Marci at over-clock....
I agree looks vey much like the old 'tech block....supposed to be a better performer tho....
Come on guys....DYE colourings....spec feedback pretty please
That block has become fairly popular over at XS. So far Maxx hasn't been able to finish up his test rig to test it out but in general the Storm and the MP-05 are the same performance wise. And Kemp, the outside may be similar but the internals are different ;)
Ya know WC you sometimes have to realise that others do read too ;)
I have blooooo - and it's nice
Red is hard as I have never really seena red-red....most are pink :p
