dipzy
Active member
sup peeps,
its been a long time since i wanted to watercool my rig but its never happened. I've just watched Tom's 400th Youtube vid and saw he's going to watercool a RV02/FT02 (the box was for a FT02 so im thinking its that one).
I do see that its not an easy case for watercooling as it more of an air cooling case but i've see builds where it has been done and now Tom is doing it also so i see now is the perfect time for me to go for it and also gives me an excuse to keep my folding temps, which are 91c atm, down.
The rad is pretty much sorted, its going to be a magicool triple 180mm, it uses G1/4 threads but this is where i get stuck, with all the ID and OD.
This is where i need the help, to select fittings and tubing.
Only going to be doing a CPU loop
