NeverBackDown
AMD Enthusiast
So been looking into some real kits lately ever since WYP posted about EK's new P line kits, however noticing that while they are great, are nearly the same price as the X line(extreme line) and for a 360 kit, was nearly $400. I came across there L line series and for a 360 is only $250.. safe to say much much cheaper and XSPC kits don't offer any pump/res kits in this price range, which I need since i have no drive bays. So they seem to be my only option. The L series are cheaper since it uses a weaker DDC pump and smaller res, whereas the P/X use D5's/taller res.
What is the big concern to me is the L kit pump. EK-XRES 100 DDC MX 3.1 PWM combo, which is more than enough for the CPU only loop, however if I ever added say another Rad or GPU block, would it still be enough? I have the room in the Define S for two 360's(tight fight but both are thinner rads). I wouldn't really ever go above a single CPU/GPU loop so that is as much as I would push it. However currently I won't be off the bat adding more blocks or rads, that will have to wait. It would just be a CPU only loop for a while. I don't see the point in putting the fury x in the loop when I plan on selling it soon for Polaris GPUs. I'd just like to know if I have the expandability option of using the slightly weaker DDC pump in a bigger loop or if the extra price increase would be worth it for the stronger pump. However at that rate I could probably custom pick the parts and get it cheaper I'd assume.
If more info is needed just let me know!
Thanks in advance
Thanks in advance
