Watercooled Ryzen 3rd Gen Rig
Finally made some updates to this system. Its now a 5950x based system (put my 3950x in my sons pc), 128gb 3600mhz ram and I replaced my main drive with a 1tb 850 WD drive (put the 1tb 8200 pro old main drive in my server) and kept my 2tb 8200 pro data drive. I also added an elgato 4k60 pro and I replaced my main 34" 144hz LG monitor which I broke with a 38" 175hz Acer predator.
I also replaced the Cpu block with a new one.
I've started to replace the cables with cablemod cables also.
I've also changed the loop order to make it look a little cleaner and fill out the case a little bit more.
This system has been been nearly fully upgraded. The only thing that remains the same is the case and cooling.
Its now:
5950x
64gb Crucial Ballistix 3600Mhz ram
6900XT GPU
Nice clean build. Did you have trouble running 4 x 32GB?
I had to run the ram at 3300mhz but it worked fine, this ram wouldn't work at 3600 even with two sticks though with Ryzen.
I replaced it with 64GB G.Skill 3600mhz ram for looks.
