Scoob
Active member
Hi all,
I’m hoping to run my ideas past you all here to get your views on various water cooling bits.
For the record I currently run a 2500k @ 4.6 using an Antec Kuhler 620 push/pull, and a pair of GTX 570’s on standard air cooling. All this on an ASUS P8Z68-V Pro Motherboard in a CoolerMaster 690 II lite case.
My plan is to migrate this into a larger (TJ07) case and properly watercool it.
Here are my ideas regarding parts I’ll need – I’m not set on particular makes of item yet and would welcome your input. Much of the below is from my original plan to water cool it all in my 690 II case, but I now want the space a larger case offers.
I don’t have any particular budget, but don’t want to waste money of course. Equally I do want to do this right and not overly compromise things just to save a tenner.
Right, my bits:
Case
- Silverstone TJ07, black with large window
GPU Blocks
- EK-FC580 GTX+ EN (Nickel) – for my Palit GTX 570
- EK-FC570 GTX SE EN (Nickel) – for my Inno3D GTX 570
- OR plain copper versions
- Do I need some sort of SLI block for the card to join them? Also, are these blocks serial or parallel flow? I was planning just to make what I needed using compression fittings and tubing...though I'm unsure if spacing will make this tricky or not.
CPU Block
- XSPC Rasa, this was recommended to me, though I don't know much about it
Pump
- DDC Ultra 18w (Pump top needed?) *
- I think my loop will not be that restrictive, limited to three blocks as it is. So a higher-flow rather than higher pressure (less flow) pump might be needed
* Pump tops, do they just change flow or does it include changing the impellor as well?
Reservoir
- Really not sure, I had originally thought bay res, but this will spoil the look of the front of the case in my view. I like the cylindrical reservoirs but I'm not sure how easy to mount they are and if further case drilling might be needed.
Radiator
- 480mm, as thick as I can go with push/pull fans – this will be fitted in the base
- 360mm – (EK-Coolstrem RAD XT 360) I already have this, will only add in if single 480 in base can’t do the job. If this is the case I will likely go dual-loop with the 360 managing the CPU. I know I’ll need to mod the case slightly to fit a 360 in the top if needed. *
* Note: I like the idea of dual loop to use two different colours of Mayhem Aurora/+
Fans
- Recommend me some
I’ve been using Alpenfohn Wing Boosts quite happily so far. Ideally I'd like a fairly quiet PC, but cooling is of course important. Fan choice is HUGE!
Tubing
- XSPC ½” ID, ¾” OD clear tubing throughout
Fittings
- lots of each, spares are good
- Provider-wise I'm not sure though bitspower/alphacool have been recommended.
- Compression fittings for ½” ID, ¾” OD
- 90 degree rotary of the above
- 45 degree rotary of the above
Coolant
- a Mayhem pre-mix to start with, hopefully Aurora/+ once I’m happy with loop.
Things to consider:
- Are there any bits I've missed? I.e. things I need to plumb everything up? I assume a pump comes with what you need, as does a reservoir etc.
- Filing the system, should I include some sort of t-piece I can run to a funnel for easy filling?
- What about these fittings that let you remove parts of a loop leak free? I.e. when you unplug them they self-seal like those garden hose attachments? Don't know what they're called.
Note: I wanted to experiment with parallel flow for my GPU cooling, having read up a fair bit on this lately and being impressed with the results people are achieving. Obiviously if I go single loop the CPU will be part of this, but ultimately I may go dual loop - in part for the fun of the build as well as better cooling. Stage one as a single loop with just the 480 is likely the way I will go initially - if this proves to work well then I'll leave it there...for the time being
This is my first proper attempt to pull together a list of parts, I hope to refine it as I get feedback. I did suffer from a bit of information overload when I first started spec'ing up bits I admit
Cheers,
Scoob.
Right, my bits:
Case
GPU Blocks
CPU Block
Pump
Reservoir
Radiator
Fans
- Recommend me some
Tubing
Fittings
Coolant
Things to consider:
Cheers,
Scoob.
