Here are some pics of my test rig that I am using to assess my waterchiller, Titan 150.
I know that it is not the most powerful piece of cooling equipment ever but firstly I only want it to chill the water to between ambient and zero and secondly I enjoy playing with all this stuff and I can't afford the more expensive versions. So my question is this if I am cooling the water to around 10 degrees is a passive resevoir, like the zalman shown, or the XSPC series that I am interested in, counterproductive? I know that these components use the temperature difference between the water and the air to normally dissipate a minor amount of heat. If however the water is cooler than the surrounding air will these components warm it up any amount? I had considered that using a resevoir like this or even a spare radiator might pre-cool the hotter water. The test setup is using a venice 3500+ and a 6600gt both with thermaltake blocks. The water temp coming off the chiller is around 10 degrees with the chiller set to 4 degrees. MBM5 says the cpu is 22 degrees so I hope the nexxos blocks for the final system are better than the thermaltake ones.
So passive resevoirs help or hinderance?
