Rob_the_scot
when I was building my pc my friend suggest I should fit a water cooling system in my pc said it would look pretty nice in such a small system if done correctly.
Now I admit always been interested in water cooling but water plus electric scares me
Now my main problem is what brand? should I go with is it really worth? since my case is pretty small.
Heres my 2 options
1: I have a rear 92/80mm fan so I could fit a 80mm radiator on the inside of the case and have a 5.25 combi res/pump
2. I have a bottom mounted 120mm directly under the gpu...but I get the feeling it might hit in some problems
I do have a final option I have 2 x 120mm front fans and the way the the case is made I cant bolt a radiator to the inside of the case due a lip that stops any thing bigger than 120mm being fitted....I hope I make sense with that 1.
my last option is this but looks impossible to get
http://www.asetek.com/products/oem-standard-products/cpu-products/92mm-products/545lc.html
Heres my 2 options
