Water Cooling + LAN Parties = ???
JohnBonson
I am considering moving from air to water cooling, one of my reasons for putting it off is that I move my computer around a lot, put it in the car and drive around. i am always as gentle as possible with it but I am worried something bad will happen. Should I just stay with air or can water systems handle a bit of moving around. If so what is there something that is more suitable than others? I am not keen to get a closed loop system as I am also looking to cool my graphics card soon too if possible.
I drive my pc around quite a lot, its got an xs-pc kit on it and I havent had a problem yet. Obviously just make sure the tubes are secured well and you shouldnt have a problem.
i Used to goto lan parties a lot and all ways had water cooled pcs to take to them.
Never had a problem at all just use your common sense.
I have a BitFenix Colossus and I know the RX240 fits and people have had trouble with other rads, money is not a massive issue, I will keep looking
If you want to be extra safe, you could drain your loop before you drive around and just refill when you arrive.
I used to do this with my compression fitting build, and when i built my LAN comp i used barbs which i find alot more secure.
