want better memory
KING_OF_SAND
So yea i currently have some memory from some company that is just not cutting it for me. its 4gb of 1333 9-9-9-24, i am having the impression one of them is failing on me as sometimes after reboot one of my sticks wont show up on CPU-Z. so i want to replace them.
my criteria is at least 4gb, 1333, OR 1600, better timings than i currently have, and under $80.
my MOBO is a crosshair formula III with a AMD 965 at 4.01 ghz.
you can also click my sig for more info.
Umm u wanna buy it from someone or looking for suggestions if its the latter go with either mushkin ridgeback or kingston hyper x or even dominator ill post links
For starters dont bump threads after a couple hours or the umpalumpas will make the whole thread dissapeer.
A budget wouldnt be a bad place to start dude.
cheap - 1600mhz mushkin silverline
midrange mushkin redline 1600 6-8-6
you wont need more than 1600 with amd.
i said under $80.
also my mobo can only go up to 1600mhz
