Vista 64 bit - GX2 - 3DMark error
Mr. Smith
I was torn between putting this here or in the benchmark team section...
OK, if you were wondering why I hadn't submitted scores for the GX2 it is quite simple. 3dm06 won't work! I couldn't be bothered to try other 3dmarks (1/3/5 as the gpu works fine.)
I tried installing an re-installing, running as administrator.
The error is something like OpenAL.dll missing? I know that is the sound thing 3dm06 installs and it is there. Anyway I just d/l'd that specific .dll and whacked it in the folder and then I got some other error.
This is all from memory so I can't be specific atm, I will add screenies tonight.
Anyway, are there known 3dmark/64 bit errors. I know Matt reviewed it without any jipp so...???
TYIA
Aaargh, I had that with the 3dmark I installed as a file I always used from the utility drive.
I went off and downloaded another one and it worked.
I can`t be 100% sure if it worked without something being done to it tho. >.<
I'll try another version Rast but the one I have is recent...
Pyr0, that didn't work
strange, i get the same error when installing 3dmark06, but the oalinst.exe in that link solves it for me...
did you run the openal installer as an admin too?
