VFD Screen Extension Cable??
stocky
I'm planning on mounting my VFD screen high in my tower case form the control board. The current cable is not long enough and I don't want to solder my own cable as there are about 20 wires!
Are there longer/ ext cables available off the shelf?
Cheers
think you will have to build your own mate or get two standard ones and join them with the pin connector thingies like for your power on the mach2
