UV reactive purple dye/fluid
Perturabo
Hi guys,
I've been looking for some UV reactive purple dye and so far the only one I have found is made by Feser. The colour looks great but the only time I hear Feser mentioned is in conjunction with "look at all this gunk in my blocks". Anyone know of an alternative or if I could mix that up somehow? Mayhems purple dye looks good under normal lighting so if I could make that glow a nice deep purple under UV I would be happy.
UV purple isnt UV purple its a mix of Purple + UV Clear Blue.
There is no such thing as a real UV purple sorry to say.
You can all so take purple and add UV pink to it or UV yellow green.
Ah right, that would explain why im struggling to find it. Thanks for the mixing suggestions, I will have a go at making some up when I get the rig together.
