PORTAL gun mod!!!:
http://ut2004.levels4you.com/forum.l4y?do=view&t=149596
Stewie Griffin voice pack:
http://software.techrepublic.com.com/download.aspx?docid=200074
(also Darth Vader, Bender and Homer Simpson packs)
UnWheel pack:
http://www.fileplanet.com/141532/140000/fileinfo/UT2004---UnWheel-Beta-3.0---MSU-Version-[Exe]
___________________________________________________________________
Widescreen res options:
Run the game once, and open the ut2004.ini file in a text editor, and find the following lines:
FullscreenViewportX=
FullscreenViewportY=
Set these to your desired resolution. On a Dell 2005FPW, this would be 1680 and 1050.
Now open the file user.ini in a text editor, and find the following lines:
DesiredFOV=
DefaultFOV=
Set these to 100 (default is 90 with a 4:3 resolution)
This solution should work on most games based on the Unreal Tournament engines. The file names may be different, but the strings should always be the same.
Source: http://www.widescreengamer.com/u/unreal_tournament_2004.html
More to come!
A search on download.com or Fileshack for "unreal tournament 2004" will turn up a ton of map packs etc.
UnWheel pack:
DesiredFOV=
DefaultFOV=
More to come!
