Also should allow in theory DP 2.x or 3.x to allow 160gbps unidirectional bandwidth since they transitioned to USB-C form factor and specification. That would allow full 10bit 8k 144hz no DSC content to be displayed.
Thank you so much for introducing me to the incredible world of encabulation. Now I understand that my life has not been complete without it.
Being a simple tech person, I enjoyed the Chrysler one, with its clear instructions of testing the encabulator, including:
If it's below 10 RGs, you'd be directed to perform a series of tests that will effectively raise the billable hours for the service department but will perform no other useful function.
Got to say I now see the world in a completely different light thanks to your comment. For people in a certain field it's often not clear how much technobabble there is.
I just read the Mutter description on Github, which says, for example:
"When used as a Wayland display server, it runs on top of KMS and libinput. It implements the compositor side of the Wayland core protocol as well as various protocol extensions. It also has functionality related to running X11 applications using Xwayland."
and
"Internally it uses a fork of Cogl, a hardware acceleration abstraction library used to simplify usage of OpenGL pipelines, as well as a fork of Clutter, a scene graph and user interface toolkit."
