Urgs ! Time for a new HS ?
FalconFX
Hey there. As some of you know i am using the Stock AMD 64 Fan ATM.
Yeah was pretty fine but after now about 3 month's my Temps are going up to idle : 41 °C and @ work almost 50.
I dont like that.
I mean a winchester can be sooooo much cooler.
Thinking about the Thermalright XP-120 or the smaller version in CU format....
Compined with a nice panaflo 120mm.
Any other Suggestions ?
Ahhh and BTW : my NF4 chipset is running on 41 °C :eek: I would say its a little high isnt it ?
you have a couple alternatives.
you can buy a XP120 and lose a couple RAM slots.
or a XP90c which is much smaller and has better ratings.
but you sy your northbridge is heating up?
well then if you want whole board cooling along with CPU, get a zalman 7700CU. they rock.
or you can get a XP-90c and a nice triple blade fan from www.sidewindercomputers.com
and then a small NB cooler (one of these) http://www.newegg.com/Product/Produ...ice=&MaxPrice=&SubCategory=62&Submit=Property
over all the HS's here, I would get a XP-90c or actually EVEN a XP-90, they cool well too.
Agreed with PV on the heavyness....especially if you move you case around a lot. The XP-90 is fine tho.
With myXP-120 I do NOT lose any RAM slots. On the contrary=the panaflo fan on the XP-120 cools the RAM's down as they are right below it :)
i would recommend the xp-120..because as you know winnies run cool...and so the big surface area of the 120 should be able to dissapitate heat easily without the need for a loud fan (not even a fan at all at idle). this is what swayed me..
name='FalconFX' said:
then i will probably take the XP 90C
okay, but id get the Xp90 or XP-120, save some money, and the XP-120 is probably the quietest.
XP-90c is good if you mount your computer on its side, otherwise it could bend your mobo :eek:
that's bullshit :rolleyes:
mine isn't using the special metal backplate.... i've even dropped it on my mobo with no apparent damage from that. all my problems lie within my ram :(
Go with an XP-120/90/90c, none of them will do u wrong and they all perform very similarly, it all boils down to space and looks in the longrun :)
Yep well madshrimps did the test, and the XP-90C appears to be the most efficient (fan dependant). It still is a heavy mofo at almost 3/4's of a kilo.
