IT WORKS! One fan at the front doesnt spin but at the moment, im pretty proud of myself. I know I didn't do it on my own so thanks to all you guys too!
Does it matter what ones I plug them into? I can't remember without looking but there are some 4pin ones on my motherboard, obviously CPU fan is for the H60 but I used a 4pin header for a 3pin fan
Also looking at it there isn't enough headers for the fans I want. One H60 fan, one for H60, one for fan at the front... I don't think there are many left!
When I get home tonight from work i'll upload some photos, maybe tomorrow install windows, have a look at my idle temps ect.
Nah you can use 4pin headers for 3pin fans, just leaves the 4th pin out, so no PWM control (cause the header supports it, but the fan doesn't).
Do you need any additional fans other than the H60 and front fans? I've only got two fans as well, although my front fan is a 230mm one :lol: You can also get some nice sleeved Molex > 3x3pin adaptors at 5v (silent), 7volt (balanced) or 12volt (full speed) by Bitfenix. Should not be too expensive and gives you the option to hook 3 fans up to your power supply's Molex connectors.
