Urgent Help needed plz - Masterkleer Tubing PVC 19/13mm (1/2"ID) Clear 3.3m (10ft) Bo
xxKrystalxx
posting for my partner since his pc is in bits for installing a water loop.
Ok so he needed Masterkleer Tubing PVC 19/13mm (1/2"ID) Clear 3.3m and it hasn't come.
His question is can he use HighFlex Hose 1/2" ID 3/4" OD 19/12.7mm
Thanks
If that's the correct tubing size for the fittings then that shouldn't be a problem. 1/2", 13mm and 12.7mm will all be the same specification of product.
JR
