Upsize me a heatsink pls
this is just getting stupid imho.
the challenges should be to create something that is small, compact, and silent, yet can draw huge amounts of heat away
love it would like to see a review though dose makeing it that big make any difference
also how the **** do you install it ???
it would be cool if you could use it to cool your vga 2 with extra heatpipes
name='deathwish' said:
it also depend on how mutch the heat pipes can transphere
Heat pipes usually just consist of a talc like powder or a liquid like water with a wick. Heat pipes are usually very efficient at drawing heat away
Scythe pwns, but that thing is lawlertastically huge!!
And I thought the CM Gemini II was a monster, this deffo takes the cake.
WE DEMAND A REVIEW lol
purlees?
on a side note...........to upgrade ANY part of your system you have to take the fan + heatsink off each time :/
RAM upgrade........take off heatsink
Wireless NIC........take off heatsink
u get the point.
lol that's mental :)
could they do one for a tower case with a fan behind it so you can use it to heat the room ?
