Hi all, I have been an OC3D follower for over a year now, and have decided to make myself an account, so a hello to everyone
Ok...
I'm looking to upgrade my case rather soon, with the hope of upgrading to watercooling closer to the end of the summer, and wanted to start getting parts over the next few months, however, I have a few questions. So here I go (bear with me on this one
Well, I'm after a case that its quiet and has support for a full size 360/420mm radiator (preferably in the roof), and 4 or 5 optical drive bays (yes, I use them) and I think I've narrowed it down to the NZXT Switch 810. So my first question is, fans. I'm after fans with good air flow, but still remaining silent (or rather, quiet). I know the Noctua NFF-12's are great at this, however, they only come in 120mm, and seeing as the Switch 810 has support for 140mm, then why not use this feature. I was thinking possibly the Bitfenix Spectre's, but any suggestions would be appreciated
My next question is, seeing as this is my first watercooling build, I'm a bit unsure on 1 or 2 things. The first being, rad's. What rads are better for keeping temps low, or rather, what manufactures. For instance, is there any differance between the likes of a Phobya 420mm 60mm thick rad and a Aquacomputer 420/60mm rad?
Another question is resivoirs. I've noticed companies such as Koolance and Alphacool have released res's where you can fit a D5 pump directly to the res, such as the Koolance RP-452X2 which I really like to make things neater within the rig. Does anyone have any experiance with these and are they any good, or would it be better to buy a separate D5/DDC pump and then floor-mount the pump in the case?
My final question is regarding CPU water blocks. Is this again a chose of preferance in looks, or is there any thermal pro's/con's between the differant manufactures. For instance I'm a fan of the looks on the Koolance 370 block, but is there any benefit getting this block, than one 1/2 it's price?
Any feedback is appreciated on this
Oh, Im currently running a 2600k OC to 4.5Ghz with an ASUS Sabertooth P67 mobo and a D-14 and all in an Akasa Infinity case (I hate the case, hence the reason for upgrading).
Cheers guys
Ok...
Cheers guys
