Just thought I would post this for anyone else who is having problems updating the firmware on there Mach units.
Get all the software and firmware from here - http://extremeprometeia.com/software.htmlhttp://nventiv.blue-nexus.com/
How-To
1) Find a second working PC with a motherboard USB header, or air cool the one you plan on installing the Mach on.
2) Install the Mach2 software on the system and plug the Mach2 into the USB header.
3) Unzip the firmware file and place the .ste file in a folder you know.
4) Find "Bootload" in the Mach2 software root directory (if you can't find it I have a standalone version I can send you).
5) Open Bootload and check it is seeing the Mach2
6) Press "Bootlad" and a dialog comes up asking for the directory for the .ste file
7) Select this file and hit ok
8) The Mach2 then fires up and says on the display "Bootloading .... load of random numbers (This is the hex code for the PIC in the controller just ignore it).
9a) Mach2 shuts down and Bootloader says "Download Complete" or something similar.
9b) To be extra sure repeat steps 4-9a again (but this isn't needed but makes sure there was no corruption, as I had mine corrupt on me straight after doing it once.)
10) Plug Mach2 back into the system it's to be used with (unless it was already on that one).
11) Do number 2 ONLY on the new system and hey presto it works
How-To
