Updated 780T Build
Dicehunter
Resident Newb
Moved from the Corsair 540, Great case but it was a little tight in areas and I wanted something with slightly better airflow and more watercooling options.
Specs -
Intel Core i7 4790K 4.80GHZ
Corsair H100i + 2 x Corsair SP White LED fans in Pull and 2 x Corsair AF White LED fans in pull.
Asus Sabertooth Mark I Z97 + 1 x red LED strip under the right side and 1 x LED strip under the bottom side.
Asus GTX 980 DCU2 Strix 4GB 980 1500/2000
Avexir Blitz 1.1 Original 2500MHZ 16GB
Corsair Neutron GTX 480GB
Western Digital Caviar Black 2TB + 4TB
Asus Xonar Phoebus + Black plexi backplate with carbon fiber Di-Noc over the top also replaced the red LED backlit "Phoebus" lettering with a solid piece of black plexi to give it a nice internal red glow.
Corsair AX860i 80 Plus Platinum + All extension cables are from Akasa as I'm quite fond of the glistening look + Custom made plexi PSU cover with carbon fiber Di-Noc over the top.
Corsair Graphite 780T + 3 x 120mm Corsair AF White LED fans at the front, 1 x 120mm Corsair AF White LED at the top and 1 x 140mm Corsair White LED at the back.
Windows 8.1 Enterprise 64 Bit Edition
Asus PB287Q 4K 60Hz 1Ms
Sennheiser G4ME Zero
Corsair RGB K95 Red Switch
Corsair M95
Corsair MM200 EE
Speedlink Xeox Pro
Shot in the dark, The fans look blue for some reason but they are white in the flesh -
Day time shot, The front panel looks quite dusty but it's actually very clean, Looks that way due to reflections -
Shot of the custom made PSU cover, Soundcard backplate and SLI finger cover also self made -
Full setup :)
I'm still scratching my head with the 450D I've mock paneled the interior and removed my white extensions, just decided I didn't want to see cables at all, so it's a work in progress at the moment.. I'll get it finished one day.
Oooh do progress pics :)
*EDIT*
Ok that looks awesome, I use to be into warhammer 40K in a huge way, I use to paint for GW now and then for their showpieces in the window so now your giving me ideas, Good old plasticard :D
That looks awesome all in black. I think the CPU cooler LED would be better if it was white though. I'm not sure if its changeable ;)
Thank you :)
Yep it is but the actual white of the LED logo doesn't go with the white of the fans, Looks a lot more pearl white than the fans frosty type of white hence I changed it to red to match the underglow of the mobo :)
Thank you :)
Ah I guess that makes sense. I forgot about the whole underglow thing you did and I never really look at the dark pictures ;)
Indeed! Eldar Wraithguard strikes again ;) 5mm foamboard is the shizznit for mocking up, or if you're neat enough a final job with the added benefits that it's A: light B: soundproof.
Nice clean build mate, nicely done with the backplate and psu cover. what materials did you use and how did you achieve that nice rounded edge on the cover?
Man do I got alot of that stuff lying around still, both fantasy and 40k
Oh, and welcome back! :)
I'm definitely a fan of the all black look :)
P.S. Welcome back to the forums Dice.
Thanks dude :)
Thank you :)
I got that rounded edge by putting the cut to shape plexi on a heating bar, I forget the proper name for the apparatus but you place it were you want it bent and the bar heats up very slowly and you push down on it with the other part of the machines arm when it's pliable until you get the curve you want :)
Thank you :)
So basically heat and pressure. Wonder if you could do it ghetto style, with like a hairblower and bending the plexi over a piece of wood or something.
Cheers.
Cheers.
My first attempt was with a bread board and the stove hahaha ^_^
Actually looked very close to this one but it had a very slight bend in the middle so I asked a friend if I could use his workshop :)
still looks like a bike to me^_^
There are bikes out there that look like PC's ? :p
