Jwbcomputers
Recently I have been going through my computer parts and found in a corner a case that was not used for anything and did have any logos on it so this is why this is going to be called the
"unkownmod" because i have no idea what case this is and i am going to be doing some modding to it.
I will be updating this case so it looks way better. Its a very small cast that allows a atxboard but it is tight so some of the mods i have planned are to take out the drive cages so there is more room around the board. i will also be taking out the front of the case so i can make a plate that will be cut for a 3 120 mm fans with 15 mm of spacing so i can put a rad in the front other mods have not been planed yet.
so the first thing done is ripping the harddrive cages out
Now that the harddrives are out i cut the front up
i will be getting a piece of metal to put in the front and mod it for a 360 rad.
