Chopper3
I have a Corsair 350D already fitted with their H100i AIO CPU water cooler but I'm toying with the idea of ripping it out and putting in a 'proper' custom water cooling setup - but I have a few questions as I've never done this before.
Firstly I know I can get in a very nice 280mm radiator from XSPC for the top, it'll fit and I'll be able to mount it either way around and still have space for the fans I'll need underneath and this would suffice for cooling the CPU. But if I want it to cool my single current 780 would it be enough or would I NEED to put in a front radiator?
I currently have two 120mm fans pulling air in through the filter at the front but obviously these would have to reverse if I put a radiator in front of them - but then ALL of my fans would be pushing out - and we know nature abhors a vacuum
so would I reverse and filter my rear fan to allow incoming air?
Presumably I couldn't run the CPU and TWO 780's through one 280 radiator right?
A further question is would you install a tube style reservoir or a bay-based one? I'm not sure where a tube-based one would actually mount in a 350D to be honest.
And my final question - do these things leak? Obviously they will if I do a crap job but even then should I expect the odd leak every so often and if so how do you deal with it (other than destroy hardware!) ?
Thanks in advance.
Thanks in advance.
