I Hunta x
After working on designs of a project im going to start building the case for in the next few weeks ive decided to try make the build as SMALL as possable with the kit im hoping to have in the new build, the case is going to be fully hand made minus possably a removeable mobo tray depending on how hard it would be to get it to slide in/out.
Specs im aiming for are either a 2500k,2600k or i7 970 depending what fund income is like over the next few months and either 1 or 2 gtx 570's for the above reason.
SOO im aiming to get the cooling good enough for the best possable outcome with that being the 970 + sli 570 (or equivilent if any new cards are out by the time i get round to buying the gpu's with to them being last on the to buy list)
Currently have the cooling planned out as 2x NON slim 240mm radiator but would be able to addapt the case to fit 280mm rads if REALY needed, im hoping 2x 240mm will be enough as the case at the moment has the dimensions of 16.5cm wide, 38.5cm tall and 43.5cm long and is currently 37% smaller than an Antec 300, 67% smaller than a Corsair 700D/800D and 73% smaller than my current CM Cosmos S
No heavy overclocking will go on realy, just a modest air cooled equivilent oc to the gpu's + hopefuly around 4ghz to the 970 or 4.5ish to the sandybridge chips due to them being so awsome.
If any one wants i can post up a render/screen grab of the layout ive got chosen so far.
-Cheers Hunta.
-Cheers Hunta.
