P Phunky New member Mar 23, 2007 #1 I've been using the TinyXP Series of Windows XP for quite some time, its a nice release with quite a lot of the crap taken out. What other tweaked versions have you used or know of?
J JN New member Mar 23, 2007 #2 name='Phunky' said: I've been using the TinyXP Series of Windows XP for quite some time, its a nice release with quite a lot of the crap taken out. What other tweaked versions have you used or know of? Click to expand... I just checked out TinyXP and ouch it's a bit restrictive. You cant even install MS Office :s On XP I used Nlite to strip out the unwanted crap. Made things a lot quicker, and I could still install Office
P Phunky New member Mar 23, 2007 #3 Yeh, thats the whole point of TinyXP they remove EVERYTHING TinyXP "666" beast edition has the most elements removed, i've been wanting to make my own one for a while but im just to darn lazy.
J JN New member Mar 23, 2007 #5 name='Phunky' said: Yeh, thats the whole point of TinyXP they remove EVERYTHING TinyXP "666" beast edition has the most elements removed, i've been wanting to make my own one for a while but im just to darn lazy. Click to expand... Out of interest, when I stripped IE from XP, The motd when joining CS:S servers used to minimise the game. Does it do this for you?
equk New member Mar 23, 2007 #6 name='XMS' said: On XP I used Nlite to strip out the unwanted crap. Made things a lot quicker, and I could still install Office Click to expand... That's all I use tbh also use it to slipstream all the newest updates into the disk at the same time. My current disk has IE removed & Windows Update removed & Windows Security Suite Removed & Windows Firewall Removed name='XMS' said: Out of interest, when I stripped IE from XP, The motd when joining CS:S servers used to minimise the game. Does it do this for you? Click to expand... Mine does that at times. Altho I think it seems to do it with welcome screens that contain ActiveX. I also get an ActiveX error on the OC3D servers, as I have it disabled for security.
P Phunky New member Mar 23, 2007 #7 It does it on servers that have HTML in the MOTD, should be a CVAR to disable viewing the MOTD tbh :/
J JN New member Mar 23, 2007 #8 name='equk' said: I also get an ActiveX error on the OC3D servers, as I have it disabled for security. Click to expand... I think that might be down to the redirection code in the motd. Its the only way to get it to display external sites
