D Davidthewin New member Mar 17, 2013 #1 My Gigabyte GA Z77X UD3H has BIOS profiles and a small red LED indicating which profile I'm on as well as a two digit red LED readout in the bottom corner. Is there any way to turn these off? They really spoil my blue theme
D Davidthewin New member Mar 17, 2013 #4 Makis said: There is no way to turn debug led codes off Click to expand... Aww Chris230291 said: Just put a piece of black tape over them or something. Click to expand... Fair point, hadn't thought of that. Thanks for the help
F Froger New member Mar 18, 2013 #5 if they are an exposed light, then you could try and break them, if not then from the back of the mobo you can unsoilder them, or just cover it up.
