Wraith Bettyswollocks Dec 14, 2014 #2 How the hell has this thread made it a day without reply... Sorry fella, Primochill rigid tubing is: Inner Diameter: 3/8in. (9.5mm) Outer Diameter: 1/2in. (12.7mm) Wall Thickness: 1/16in. (1.58mm) The Primoflex LRT is: Inner Diameter: 1/2in. (12.7mm) Outer Diameter 3/4in. (18mm) Wall Thickness: 1/8in. (3mm) Inner Diameter: 3/8in. (9mm) Outer Diameter: 1/2in. (12.7mm) Wall Thickness: 1/16in. (1.58mm) Inner Diameter: 3/8in. (9mm) Outer Diameter: 5/8in. (16mm) Wall Thickness: 1/8in. (3mm) Inner Diameter: 7/16in. (11mm) Outer Diameter: 5/8in. (16mm) Wall Thickness: 3/32in. (2.5mm) Hope this helps.
J joey117 New member Dec 14, 2014 #3 Thanks for the post , any other good tube that you can get the size i need 8mm id 11mm id
Wraith Bettyswollocks Dec 14, 2014 #4 To be honest 8mm is a real odd size for watercooling, what is it your fitting it too?
J JR23 Banned Dec 14, 2014 #5 Masterkleer have a 5/16 ID tube http://www.aquatuning.co.uk/water-cooling/tubing/tubes/10890/masterkleer-tubing-pvc-10/8mm-5/16-id-clear-3-3m-10ft-retail-package JR
J joey117 New member Dec 14, 2014 #6 To be honested a friend was selling of his water cooling stock and i got 25 fitting of 5 pounds and my pc noise levels are like a jet plane so was going to use them to make a quieter riq.
