TTL Orca Resv combo
Thanks mate you have being a big help , just watch some for ttl orca stuff and it is crazy how close are a loop setup up are . :)
The thing I am missing is the pump top I am having problem finding the right one it is not in the kit that all my problem :(
That the res I bought ( http://www.sidewindercomputers.com/bisid5topupk.html ) and thanks that clear the d5 info clear a lot up .
Follow your own link...
Part Number: BP-D5TOPUK250P-BKBKCL
The kit works with their single or dual D5 pump mod kits, as indicated in the instruction set here.
Google the part number...
...http://www.bitspower.com/html/product/pro_show.aspx?num=81092611&kind2=7
Open the instructions...
...and purchase all of the required parts marked not included.
You may have to do that part on you own.... ;)
JR
