Trophy's Rig
Trophyon
This is my current setup, I will upgrade the GPU soon (980ti maybe?) as I will use the 770 in my Mini-ITX system.
Case: Corsair Obsidian 750D
Mobo: ASUS Sabertooth Z77
CPU: Intel i5 3570k
GPU: EVGA GTX 770 "SC" 4gb /w backplate
PSU: Corsair HX1000i /w Corsair individually sleeved cables "Blue"
RAM: Corsair Dominator Platinum 1866mhz 16gb /w Blue lightbars
CPU cooler: Corsair Hydro Series H105
Fans: Corsair AF120/140, SP120 /w Blue rings.
Storage: Samsung 840 Pro 250gb, EVO 250gb, WD Black 500gb
Sound card: ASUS D2X
Monitor: Benq XL2420T 144hz/1MS
Mouse/Keyboard/pad: Razer Naga 2012, Corsair Vengeance K90, Corsair MM200 Extended
Speakers/Headset: Corsair SP2500 gaming sound system, Corsair Vengeance 2100 7.1
Webcam: Logitech C920
Chair: DxRacer F-series Formula
Would you say getting a DX Racer is worth it? I have some money waiting to get one but
I am unsure
Well as you can see in one of the pics.. Before I got the DX I used an Ikea like chair and my back and bum hurt after just a couple of hrs. Now i've had the DX for about 2 months and so far I can say it was totally worth it, I can sit 6hrs+ without any problems. Just be sure you buy the right sized chair for your body. :)
Yeah I am using a similar looking chair to your old one, and it is awkwardly shaped. It has a curve in it and my back is paying the price. I think it will be a purchase I will make then. Hopefully buying a DX Racer make me go pro at CS GO hahaha got to have hope
Idd Sir, I hope you'll find it better with a new chair, it truly helps and absolutely an item worth paying a little more for if you spend alot of time on the computer.
Nice! Very nice in fact tidy build and excellent work on cable management.
Thanks alot, colorscheme and cable management is important! :D
Looks great. Your cable management is awesome. Im jealous :) Love the LED's btw, they match the blue accents of your rig
Thanks! I used to have blue led fans and two led strips in there... imagine the horror. Now Theres only one led strip thats half way taped up with black tape. Less light helped alot getting the blue accents to come forth :)
