Hello, I recently got my 2 new 24 inch monitors to place beside my BenQ XL2420T monitor. But when I try to play with them all via Nvidia Sorround, the monitors in the side seems to have a very big zoom on it. How to fix? Tried with both BF3 and TF2. Same thing.
They're all the same resolution. I do BF3 with 90 FOV. But it's the same on normal. If I turn to look with my side monitor, I can almost see a cross the map, and it is very pixelated.
Can you take a photo to show us the issue. I play BF3 @ 5760 x 1080 on the same monitors as you and there is some obvious stretching on the side ones but I'm pretty sure this is normal. For example have a look at this pic (not mine but shows what I mean):
If you've got something worse take a photo and post it, it'll help us help you.
Also what cables are you using to hook them up? I use DVI dual link (bottom right):
but from time to time the screen tells me I'm using the wrong type of cable... I just switch the screen mode and it seems to fix it and get rid of the message.
I use a DVI Dual Link. But looking at your picture, it is looking way better in the sides! I'll take a picture when I get home. Is yours through Nvidia surround? Mine is, and it's causing this very large zoom in every game. Again, I'll take the picture when I get home.
I think triple monitor gaming is too much hassle right now, I'd have a dual monitor set up just with the main one for gaming and the side one for other stuff, which is exactly what I did until one of my monitors died a couple of weeks ago lol.
I can't wait until curved ultra widescreens are easily available so that it's one curved screen the size of 3 1080p screens side by side, that'll be so awesome I hate the black bands between the screen in triple monitor setups
