Lo guys,
I've been thinking a bit about K404's idea about a touch screen and how it would look in my Mach rig. Heres the screen I've been reading about...
It's a Lilliput 7" touchscreen made for cars. I've done a bit of research here and its quite easy to strip out the LCD. As you can see it has a VGA input and the USB is for the touch screen software. I was thinking of modding it into the lowest section of my rig which contains all my water cooling parts, here...
I'd have to make a new front panel but my only concerns would be that it would break up that Lian Li hole pattern, which I think looks really cool. I've checked out the dimensions of just the screen (it's a Hitachi TX18D11VM1CAA) and it would fit right in the front there. As my PC is on a pedestal cabinet the screen would be at just head height whilst I'm sitting in my chair. I could then make some samurize screens to monitor different system readings. I could even make them touch screen activated too, I've checked out the software for the screen and it seems pretty easy to use. What do you think a screen would look like down in the bottom of my rig there? or would it just break up my Lian Li hole pattern? This screen can be bought for about £150.
Cheers guys.
Cheers guys.
