Thumb screws
Dawelio
Active member
Hey guys,
Anyone of you know where to get blue thumb screws that actually fit in the "standard" thumb screw holes?... as I got something like this and the threaded pin is too thin for the whole, so it doesn't screw on, just goes in and falls.
Hope you get what I mean here... thank you.
Regards,
Chrazey
Okay, as I got these and they didn't work at all...
showproduct.php
Should've probably read the description :p
These screws offer tool-free mounting of various parts on or in the case and are limited to use with Lian Li cases and Lancool. They allow, for example, the locking of the side panels on the tower back, without the need for a screwdriver.
Although it is weird that they don't mention the size, but yaknow...
