thoughts?
Do a comparison of both. You should be able to switch between them, I think. Keep the the one you like more. If you can't make out a difference, stick with the onboard or if you really like a feature of the creative driver or software, go with the audigy.
Basically it comes down to personal preference and usecase.
Audigy 4!! by YARDS
As if you still have one!
thanks sub an i dont have one myself, my mate did in his old rig. i'm just cannibalizing what i can for him as i am updating (an cleaning :/) his rig, so i will use the Audigy 4 that means i can take the front IO audio cable off.
