Thermaltake Urban T81
Dicehunter
Resident Newb
Nice change of direction for Thermaltake, Might consider this for s future build.
Thermaltake Urban Series' new full-tower allows multiple fan and radiator setup installation, along with a "Suicide style" left sidepanel design
Thermaltakes new full-tower, It's Urban Series: Urban T81. According to the company, The case is designed to provide enthusiasts to build "Highest performing system" while sticking to simple appearance.
The left sidepanel design is inspired by automotive "Suicide doors". One panel with a lock is for the motherboard tray area, And another one dedicated for the HDD bay. The full-tower supports eATX form factor motherboards and has a very large support list for multiple fans and multiple radiator support.
The case supports front 360mm/top 420mm or front 420mm/top 360mm radiators along with 120mm radiator for the rear and 120/240mm radiators on the bottom, Ensuring the users get variety of options to install radiators of their preference.
The specifications are as follows:
I actually quite like the Urban series and you could say that its incredibly un thermaltacky. Thanks for showing I'm not the only one ^_^.
Hopefully this means Thermaltake has woken up and realised that if they actually try they could take on the Giants who actually make decent products.
Forgot you don't like Thermaltacky :blink:
How could you forget? :P
even though the showcase build is god awful this is quite good for thermaltacky standards.
don't really like the doors and the feet look like clunky, but at least there is proper radiator support this time.
IF this had a few bits changed I'd actually consider it as I love the rad support. As it stands I'll probably still go for the Aquarius X90 or something else.
I mean, look at that rad support. Perfect for a newbie to water like myself.
I'm looking at it and i'm not seeing anything wrong with it. Its not something I would buy but it doesn't look like something you shouldn't buy.
Design wise it looks pretty good and it certainly has all the right features. What we can't tell from pics is how good the build quality is, which will probably be its downfall.
If it's anything like this Thermaltake urban s31:
I would stay well away from it. I watched this review a while back (wasn't interested in the case, but wanted to see what it was like. The panels aren't flush, very plastic looking. The front panel to get to the optical drive wouldn't open fully so couldn't get a dvd drive etc... in there, and this guy had the clips snap off (made of cheap plastic? Nuts!) All this for a price of a Arc midi, r4, or many great cases (Nzxt, Corsair etc...)
Now they could have changed something, but i don't trust them at all. There is probably alot more wrong with it if you can watch the whole video. For the money a very bad case! :o
